  • LeiUmbraco 3 posts 33 karma points
    Jan 13, 2014 @ 12:36
    LeiUmbraco
    The red asterisk for mandatory fields is not showing up.
    The red asterisk is working in Contour form builder, but it is not showing up in form preview. It is not showing up in the live site either.
    Any help is appreciated.
  • Comment author was deleted
    Jan 14, 2014 @ 12:59
    Make sure you setup the settings of the forms correctly, indicate mandatory fields, and set an indicator :)
    Jan 14, 2014 @ 13:19
    LeiUmbraco
    Thank you Tim.
    After setting an indicator the asterisk does show up but it is not in red. If I define the CSS as .mandatory {color:#ff0000;} the whole string becomes red. But I only want the asterisk to turn red. How to fix this? Thank you!
    Jan 14, 2014 @ 14:17
    That's just css :) check the class on the asteriks :)
    So that's the class contourIndicator
    Jan 14, 2014 @ 14:28
    LeiUmbraco
    It is contourIndicator! Thank you Tim!
