When tring to edit the values of a submitted entry, I am getting the error shown below if any of the captions on the form contain spaces.
Is there a known way to get around this?
Source Error:
Null ref error when editing entry values
Source Error:
This is in Umbraco v6.1.6 (Assembly version: 1.0.5021.24867) using Umbraco Contour version 3.0.17.
Comment author was deleted
Hmm that's strange, could it be that the form changes structure (so fields added/removed) when compared to the record you are trying to edit?
How would I best go about detemining if this is happening?
Check fields in entries viewer and check fields on the form :)
