  • Greg Fyans 140 posts 342 karma points
    Jan 16, 2014 @ 13:14
    Greg Fyans
    Issue programmatically updating record fields
    I'm trying to update a field value on a partially submitted form, using a custom workflow in Contour 3.0.18. The workflow is set to execute when the form has been PartiallySubmitted.
    This is my code:
    public override WorkflowExecutionStatus Execute(Record record, RecordEventArgs e)
        record.GetRecordField(fieldId).Values.Clear();
        record.GetRecordField(fieldId).Values.Add("123456");
        RecordStorage rs = new RecordStorage();
        rs.UpdateRecord(record, e.Form);
        rs.UpdateRecordXml(record, e.Form);
        rs.Dispose();
    The record field type I'm trying to update is of HiddenField.
    It is updating the value (I've attached a debugger and can see the record field value is being modified) but it doesn't persist it to the database.
    I've compared this code with an example on Tim's blog, and apart from the fact that he's creating a new instance of a Form and I'm using the instance passed in the Event Args, it's the same. However, I've also tried creating a new instance of a form and that doesn't work either.
    Any ideas?
    Greg.
  • Comment author was deleted
    Jan 16, 2014 @ 13:19
    Any reason you are adding this to the partially submitted? generally when updating record values I recommend to do this on the approved stage (so final stage) to avoid conflicts
    Jan 16, 2014 @ 13:22
    Greg Fyans
    It's part of a multi-step application form that has resume functionality. I need to add this after the very first step is submitted so the applicant can abandon the form and then resume later.
    Greg.
    Jan 16, 2014 @ 13:27
    Ok will do a test run and see why the value is being overwritten, more details later today
    Jan 16, 2014 @ 13:28
    Greg Fyans
    Cool. Thanks for looking into it.
    Jan 16, 2014 @ 16:18
    Looking at the code... manipulating the record should do the trick, trying to debug now, hopefully I'll have a solution for you today
    Jan 16, 2014 @ 16:46
    Ok seems it's due to the fact that the record is being passed as a value and not as a reference, so the changes will be overwritten, looking into a fix
    Jan 16, 2014 @ 17:38
    Greg Fyans
    Top man, look forward to it. Basically got this whole implementation working, just need this and I'm done :)
    Jan 16, 2014 @ 17:41
    Ah the pressure :p hope to get a solution for you tomorrow, stay tuned!
    Jan 17, 2014 @ 09:55
    Been trying different things but always end up with breaking changes so can't introduce that in Contour at this point :( what I would suggest is that you just create an extra table and store your extra record details in that one (linking it to the record id)
    Would that work as a workaround for you?
    Jan 17, 2014 @ 11:23
    Greg Fyans
    Ah, OK, I'll look into a workaround. Thanks for trying.
    Greg.
  • Bo Jacobsen 585 posts 2361 karma points
    Feb 12, 2016 @ 09:27
    Bo Jacobsen
    I got the same issue. I want to update the record with the currentUmbracoPage informations on submit.
    But it won't update the record and if i get the record to udate, it crashes the server.
    Dont update this way as i though it would.
            record.GetRecordField("Aktivitet").Values.Clear();
            record.GetRecordField("Aktivitet").Values.Add("1, aktivitet");
            var fs = new FormStorage();
            var form = fs.GetForm(record.Form);
            var rs = new RecordStorage();
            rs.UpdateRecord(record, form);
            rs.UpdateRecordXml(record, form);
            fs.Dispose();
            rs.Dispose();
            return WorkflowExecutionStatus.Completed;
    Update the record, but crashes the server
            RecordService.Instance.Submit(record, e.Form);
    Updates the record field if not set to manuelly approve submitted records. If i want to manuelly approve the records, it wont save it to the fields, but it sends the field data that is not set with the currect value in a mail.
            record.GetRecordField("Aktivitet").Values[0] = "1, aktivitet";
    I will make a new post about this. its urgent for me..
  • Romeo Cadaoas 33 posts 110 karma points
    May 14, 2017 @ 12:46
    Romeo Cadaoas
    HI Bo Jacobsen, I'm having the same issues. Where you able to resolve this?
    May 15, 2017 @ 07:22
    Romeo Cadaoas
    This works for me
    record.GetRecordField("Aktivitet").Values = new List<object> { newValue};
