Yes, I'm sure, I can get them fine with field.PreValueSource.Type.GetPreValues(field). But as I'm building the forms from an ajax request, I'd like to get everything in one request, making a separate request for each dropdown for example would delay the rendering of the form too much.
Pre-values missing from PageStorage.GetAllPages
The result from PageStorage.GetAllPages has no values in FieldSets.Fields.PreValues. Any idea what can be done?
Thanks!
Comment author was deleted
Hmm that's strange, will check what's going on, and you are sure your fields have prevalues?
I made some print screens to better show what I'm trying to do.
Could you try using the form model instead (in Umbraco.Forms.Mvc namespace)
var model = new Models.FormViewModel { FormId = form.Id, FormStep = formStep };
and return that
Great, the FormViewModel has the prevalues populated correctly!
Thanks Tim!
Awesome :)
