  • Aljosa Cakic 3 posts 23 karma points
    Jan 28, 2014 @ 11:29
    Aljosa Cakic
    Get FormId inside the FieldType's razor view
    Is it possible to get FormId inside the FieldType's razor view?
    In the version for web forms I used FieldType.AssociatedField.Form, but I can't find
    something similar in the razor script model class - Umbraco.Forms.Mvc.Models.FieldViewModel.
    I need FormId to get form's records in Razor using method
    Umbraco.Forms.Mvc.DynamicObjects.Library.GetRecordsFromForm(string formId)
  • Fuji Kusaka 2203 posts 4220 karma points
    Jan 28, 2014 @ 12:15
    Fuji Kusaka
    Hi Alijosa,
    Have you try this.
    Jan 28, 2014 @ 12:34
    Aljosa Cakic
    Hi Fuji,
    methods in the Umbraco.Forms.Mvc.DynamicObjects.Library receive paramethers pageId or formId,
    so  in the Razor script of my custom FieldType I need to get them before passing to these methods.
    Jan 28, 2014 @ 12:59
    Fuji Kusaka
    HI Alijosa,
    You want to get the pageId or formId in one of your fieldType ?
    [#pageId] in Default Value.
    By formId do you mean the number of times the form as been submitted or Guid?
    I did something quite similar making use of db instead. But somehow the formId will only be visible when a mail is being submitted on notification to Admin or anyone assigned to in the workflow.
    Jan 28, 2014 @ 13:24
    Aljosa Cakic
    Hi Fuji,
    exactly I need formId in razor script of my custom FieldType.
    FormId is big fat guid, the one from the settings tab on Contour form's page.
    I found temporary solution by creating custom setting FormId in my custom FieldType, but I beleive that exists a more elegant solution.
    WorkflowType class is something different, the Record class can be accessed there.
