Topic author was deleted
Feb 11, 2014 @ 16:08
Contour 3.0.19 is out
Containing the following fixes/features
Fixes: CON-496 Code First: Recaptcha field cause to exception in view form Fixed: CON-450 Unable to delete forms that contain conditional fields Fixed: Styling issues on the inline prevalue editor Fixed: performance boost when form is behind login Fixed: Dashboard redirects on v7 Fixed: Speed improvement on csv export Added: Events on records (insert/update/delete) Added: Conn string picker fieldsetting type, uses on sql prevalue source type Added: Make it possible to provide form step when placing form in edit mode
Get it while it's hot! http://our.umbraco.org/projects/umbraco-pro/contour
For upgrading take a look at http://our.umbraco.org/projects/umbraco-pro/contour/documentation/Installation/
Great thanks Tim
Hi Tim,
For umbraco 7 (I'm using Contour 3.0.21), is there any new ways of displaying Contour data with razor or will it be the same as the one below?
http://our.umbraco.org/projects/umbraco-pro/contour/documentation/Developer/Working-with-Contour-data-in-Razor/
or is there anyway to display the entries of the Contour form as an XML from the URL?
