  • Skowronek 29 posts 105 karma points
    Feb 19, 2014 @ 22:04
    Skowronek
    Cross-Field Validation Yet?
    I'm seeing very old forum posts regarding cross-field validation in Contour. Is that still a "feature request", or has something (workaround perhaps) been provided?
    Thanks.
  • Comment author was deleted
    Feb 20, 2014 @ 08:24
    Using the razor macro (that's default at this point) you can hook into the controller and add additional validation rules (so you can combine multiple fields in the rule...)
    Even easier is when you use code first approach details on that here (look at the validation method)
    http://umbraco.com/follow-us/blog-archive/2012/11/6/contour-30-features-code-first.aspx
