  • Skowronek 29 posts 105 karma points
    Feb 20, 2014 @ 03:55
    Skowronek
    Example of Custom Field Type Similar to DropDownList
    Anyone have an example of custom field type similar to the built-in dropDownList control? I need to create a ListBox field type that can source prevalues basically the same as the DropDownList.
    TIA.
  • Comment author was deleted
    Feb 20, 2014 @ 08:19
    You can hook the default dropdownlists to a prevalue source :)
    Just create a prevalue source first (you can use datatype prevalues/documents/...)
    Once that is in place you can set a dropdown to use the source (on additional settings)
    Tim
