Is there a way to set a custom field type's setting (and a workflow setting) as required? I am building a bunch of custom fields that all have a setting that is going to be required to be set as they'll be used in the workflow.
setting
required
workflow
Comment author was deleted
yeah you can do that in the validaiton of the workflow type :) check the sourcecode for the existing onces
public override List<Exception> ValidateSettings()
List<Exception> l = new List<Exception>();
if (string.IsNullOrEmpty(Email))
l.Add(new Exception("'Email' setting has not been set"));
if (string.IsNullOrEmpty(Message))
l.Add(new Exception("'Message' setting has not been set'"));
return l;
Required Fieldtype Setting
setting(and a workflowsetting) asrequired? I am building a bunch of custom fields that all have a setting that is going to be required to be set as they'll be used in theworkflow.Comment author was deleted
return l;
