Error in Umbraco backend after upgrade to Umbraco v4.11.10 and Contour v3.0.?
I just upgraded an Umbraco installation from 4.5.2 to 4.11.10 and thereafter I upgraded Contour to the latest version. It seems the forms work fine in the frontend, but when trying to manage them I get YSOD when trying to manage existing forms and when creating new empty ones from scratch. I have attached two screen dumps of what I experience.
Screendump when creating new empty form
Screendump when creating a form from the Contact form template.
I hope someone out there can help. Are there issues with DLLs or are some User Controls missing or???
Yes I did. But it turned out that it was an issue with the versions of Contour. I tried several different versions which all turned out to result in YSOD loading DLLs etc. When I at last tried installing v3.0.6 it worked. So it seems only v3.0.6 works with an upgraded version 4.11.10. Maybe this is well known, but I must have missed that part if that was the case.
Thanks a lot in advance.
Cheers Kim
http://stackoverflow.com/questions/21865675/umbraco-7-0-4-bundling-not-working
Comment author was deleted
Sure you upgraded all files?
Hi Tim,
Thanks a lot for the replies though.
Cheers Kim
