  • Darren Clark 53 posts 250 karma points
    Mar 18, 2014 @ 11:47
    Darren Clark
    Deleting form entry
    Hi ,
    I have an issue with contour when trying to delete an entry from a form i have created.
    I am using Contour version 3.0.1.9 and Umbraco 7.0.4
    The problem is after deleting a record the page does not refresh, the record does actually get deleted but the page will not refresh to reflect the deleted entry, you have to manually click away and then back to see that it actually deleted it.
    There are no errors generated in the browser console and the request in fiddler comes back with completed.
    Can anyone shed some light on this please.
    Regards
    Darren
    Mar 18, 2014 @ 12:47
    Hi Darren
    Is it inside Umbraco that the page is not updated?
    I think thay may be a general issue in v7 - Perhaps it's a good idea to report it at the issue tracker here http://issues.umbraco.org/issues
    Mar 18, 2014 @ 14:03
    Darren Clark
    Hi Jan,
    Yes it is in backoffice where the issue is.
    I will add to issues tracker.
    Regards
    Darren
    Mar 18, 2014 @ 14:14
    Hi Darren
    Ok, then I think it's related to other issues within Umbraco 7 then.
    Please post the issue link back in here once it's created :)
