@Tim G.
I'd like to use a previous form as a template. I can easily export and import the form. However, what I'd like to do is remove some of the formsteps w/out losing the fields contained therein, similar to deleting page breaks in a Word doc. Is there any way remove selected formstep pages from the form while preserving selected fields from each formstep, effectively collapsing the form. If not, then please consider this a feature request.
Delete Formstep w/out losing fields
@Tim G. I'd like to use a previous form as a template. I can easily export and import the form. However, what I'd like to do is remove some of the formsteps w/out losing the fields contained therein, similar to deleting page breaks in a Word doc. Is there any way remove selected formstep pages from the form while preserving selected fields from each formstep, effectively collapsing the form. If not, then please consider this a feature request.
Comment author was deleted
You can do that in the export file, it's just xml so you can move stuff around
But yeah we need to add it to the UI
This text of this message has been deleted because the XML was unreadable.
I cannot figure out how to paste the XML into this message. Using the code button on the toolbar does not work.
Maybe just post to gist or a service like that
but it's pretty simple you'll see fieldset elements and field elemets
