  • MK 428 posts 904 karma points
    Mar 19, 2014 @ 15:45
    MK
    Contour 3.0.9 on 6.1.6 is slow on submit
    Hi there,
     I have one contour form with 12 fields on it and when coming to submit the form it takes about 7-8 sec to submit.
    Ive check the form.cshtml and takes 0.2 sec to render so I guess this is not the issue.
    Any idea?
    Many thanks
    Moshe
  • Comment author was deleted
    Mar 19, 2014 @ 15:53
    Could you try upgrading to http://nightly.umbraco.org/Umbraco%20Contour/3.0.20%20WIP/ and see if that fixes the issue (do it on a staging env) if that works fine I'll release 3.0.20 soon
    Mar 20, 2014 @ 10:20
    MK
    Hi Tim,
    Many thanks for your quick reply.
    Just installed it and it improved it by 4-5 sec (any chance for more?)!
    Would love to get the new release up and running.
    Many thanks
    Moshe
    Mar 20, 2014 @ 10:21
    Ok thanks :) will get that out today then
    Mar 21, 2014 @ 11:19
    Also check http://www.mayflymedia.co.uk/blog/speeding-up-umbraco-contour-by-800-percent/
    Will get that improvement in Contour as well
  • Jason Provence 12 posts 32 karma points
    Apr 02, 2014 @ 18:26
    Jason Provence
    Sorry, does that last comment mean that we will be seeing the db updates that are mentioned in that article in a future release of Contour, or that we need to do that ourselves to see that improvement?  We have a ton of forms with a lot of entries and are running into the same problem.  Thanks!
