  • Fuji Kusaka 2203 posts 4220 karma points
    Mar 19, 2014 @ 16:04
    Fuji Kusaka
    Specified cast is not valid
    Am using Date Picker and rendering the contour form with razor but on submit i get his message "Specified cast is not valid."
    I did try the preview mode but same error and when looked in the entries nothing is in.
    Any idea what might be causing this ?
    //fuji
    Mar 19, 2014 @ 17:12
    Dennis Aaen
    Hi Fuji,
    Could it be the same as problem that Pavel had some while ago. Try to see how Pavel solved the issue.
    http://our.umbraco.org/forum/umbraco-pro/contour/46722-DatePicker-field-Specified-cast-is-not-valid
    /Dennis
    Mar 19, 2014 @ 17:31
    Fuji Kusaka
    all jqueries are working fine but still nothing.
    Mar 19, 2014 @ 17:51
    Dennis Aaen
    Hi Fuji,
    If you could tell which version of Contour and Umbraco are you using and maybe which field types your form contains, then I could try to see if I can reproduce it too.
    /Dennis
    Mar 19, 2014 @ 18:28
    Fuji Kusaka
    Hi Dennis,
    Am using umbraco v 4.11.8  and contour 3.0.14.
    Mar 19, 2014 @ 18:31
    Fuji Kusaka
    Hang on Dennis looks like its working again, i recreated the form from scratch and looks like there was a Regex in the DatePicker.
    But in my transformed xslt i get the right date format i was looking for dd/mm/yyyy instead of mm/dd/yyyy.
    Mar 19, 2014 @ 18:41
    Dennis Aaen
    Hi Fuji,
    Just like Pavel did in the post I linked to. He also remove the field and add the field again. So good that it work for you now Fuji.
    /Dennis
    Mar 19, 2014 @ 18:43
    Fuji Kusaka
    Very annoying though!! :)
  • Zac 239 posts 541 karma points
    Jun 26, 2014 @ 20:52
    Zac
    FYI - for other people running into the same issue, this is the only fix that worked for us:
    Change the \Umbraco\plugins\umbracoContour\Views\FieldType.DatePicker.cshtml
    to the following code
    @model Umbraco.Forms.Mvc.Models.FieldViewModel
        string val = string.Empty;
        if (Model.ValueAsObject != null  && Model.ValueAsObject != "")
            DateTime d;
            d = Convert.ToDateTime(Model.ValueAsObject);
            val = d.ToShortDateString();
    <input type="text" name="@Model.Name" id="@Model.Id" class="datepickerfield" value="@val"
    @{if (Model.Mandatory) {<text> data-val="true" data-val-required="@Model.RequiredErrorMessage"</text>}}
    Thanks to Craig Cronin's response here: http://issues.umbraco.org/issue/CON-382
