No just a normal created form, from the backend.
I use the Workflow "When the form has been submitted".
I can see that contour enters the workflow, and set the e.Form.GoToPageOnSubmit to the pageid i want.
But it seams that contour ignores this, and uses what is set in the backend.
ok :) well setting the gotopage in the workflow won't do the trick, what you can do is move the workflow to approved stage and just to a redirect from inside the workflow
GoToPageOnSubmit
Hi there.
im having trouble getting the GoToPageOnSumbit to work
When debuging I can see that the value is update, but is always uses the value set on the Contour.
( code here http://pastebin.com/SNn7KaTA )
Comment author was deleted
Not sure what you mean here, code first form?
No just a normal created form, from the backend. I use the Workflow "When the form has been submitted".
I can see that contour enters the workflow, and set the e.Form.GoToPageOnSubmit to the pageid i want. But it seams that contour ignores this, and uses what is set in the backend.
The workflow code is in pastebin link.
I need the workflow to control where the user is redirected to.
Hope it makes sens :)
ok could you try with this verison http://nightly.umbraco.org/Umbraco%20Contour/3.0.20%20WIP/ since there have been some change to how the record is passed around
Running Umbraco Contour version 3.0.20 WIP
Now it never hits the workflow.
Bummer... Im using this stage to actually determind if the form sould be appoved now, or redirected to a payment page.
But ok, i will redirect the user to my payment handler, and there redirect to the lanugagepage.
So now, this thread has been change to a feature request. :)
I like to be able to change the Goto page on submit in the workflows :)
Yeah will look into it :) could you add to http://issues.umbraco.org/issues/CON
Done - thanks Tim..
