  • Fuji Kusaka 2203 posts 4220 karma points
    Mar 21, 2014 @ 20:27
    Fuji Kusaka
    Issues with IE
    Has anyone ever encountered any issues when rendering contour form using razor under IE ?
    My layout just break when i use RazorRenderForm but not when using UserControl ! This only occurs under IE though, Chrome and Firefox works just fine.
    Thing is i cant use UserControl since DatePicker doesnt work well.
    Any idea ?
    I even try to clear:both but still not displaying well.
    //fuji
    Mar 21, 2014 @ 22:00
    Hi Fuji
    What version in particular? I've seen some IE8 issues but otherwise it's working fine.
    It may also depend on your own styling of the forms?
    Mar 22, 2014 @ 03:39
    Fuji Kusaka
    IE 11 but when you check the rendering document mode it says 9. I did try to emulate IE to 10 which fix it but we cant assume every user will have IE 11 or IE 10 on their local machine.
    Mar 22, 2014 @ 10:41
    Hi Fuji
    Ok - but since you write that your layout breaks I'm thinking that this is not Contour functionality but your own styling perhaps?
    Or is it the datepicker that is not working?
    Could you post a screendump or submit a link perhaps?
    Mar 22, 2014 @ 11:17
    Fuji Kusaka
    I can send you the link but on twitter since this url is still not available to guest.
    I did try removing date picker but same issue. I also inserted the contour form using Usercontrol with the Datepicker in it and works fine, the layout is not broken but the date Picker somehow does not display well.
    /fuji
    Mar 22, 2014 @ 11:23
    Hi Fuji
    That's ok - I'll have a look when you send it.
    Mar 22, 2014 @ 11:31
    Hi Fuji
    Ok, I've had a look at the site...Now, just to be clear - What exact version of IE is the problem? Is it in IE11 that it acts up? I get a bit confused when I read the above comments on versions so I think it's better you mention the browser version specifically again.
    Mar 22, 2014 @ 11:41
    Fuji Kusaka
    Its not working on IE 8-9. If somehow i Emluate IE to 10 or Edge it works fine.
    Mar 22, 2014 @ 11:43
    Fuji Kusaka
    But only people using IE 10-11 will be able to view the form correctly when emulator will trigger. But users under IE 10 will have issues.
    Mar 22, 2014 @ 11:44
    Ok, and it should be working on both 8 and 9?
    Mar 22, 2014 @ 11:49
    Fuji Kusaka
    well i would go for 9 since users on 10-11 it works
    Mar 22, 2014 @ 11:57
    Ok, unfortunately I can't use the emulate stuff in my IE11 since in IE9 it just shows a weird overlay at my machine.
    Any chance that you can somehow show me a screendump of what it looks like on your machine when emulating IE9? Perhaps just put it in a dropbox folder that you can share to my e-mail?
    Mar 22, 2014 @ 12:04
    Fuji Kusaka
    Same overlay all text displays on the the images right ?
    Mar 22, 2014 @ 12:07
    It's displays all over the site. I can't navigate the site or anything. And then it's like there's a "pause" button in the center of the page.
    Mar 22, 2014 @ 12:16
    Fuji Kusaka
    I think its something to do with the default stylesheet in Contour. I just unchecked it and looks like the form is visible and no more overlapping.
