  • Steve Wilkinson 132 posts 211 karma points
    Mar 28, 2014 @ 08:24
    Steve Wilkinson
    Where do I put Contour licence
    We purchased Contour in December and I'm trying to install it onto our Development server.
    I have the licence key but I'm not sure where I need to put it.
    If I try to do it within Umbraco, it wants me to use my umbraco.org profile to register Contour and I don't think it's associated with the licence (especially as my umbraco.org profile is my personal email rather than my work email address) - I didn't make the purchase, our Business Support Officer did via an invoice rather than a credit card purchase.
    What do I need to do?
    Steve
    Mar 28, 2014 @ 08:29
    Dennis Aaen
    101
    Hi Steve,
    Take a look at this link: http://umbraco.com/help-and-support/customer-area/contour-support-and-download/common-issues.aspx
    The license checks your domain and IP. If these doesn't match, the application will fail. If the license file is not in the /Bin directory, the application will automaticly switch to trial mode.
    Hope this helps,
    Dennis
    Mar 28, 2014 @ 08:36
    Hi Steve
    You should signup to umbraco.com - that can be done using your work e-mail. If your work has a e-mail account for things like this then you can use that. Once signed up you can setup the domain etc., which will generate a license key that you can download and put in the /bin folder as Dennis mentions above.
    Mar 28, 2014 @ 09:18
    Steve Wilkinson
    Thanks for the help. I had the licence file already, I just wasn't sure where to put it.
