  • Martin Griffiths 826 posts 1269 karma points c-trib
    Mar 28, 2014 @ 17:07
    Martin Griffiths
    Honeypot technique failing for us in Contour
    Hi Tim
    We've noticed in the last couple of months the honeypot technique you employ in Contour is starting to fail for us and we're now getting a steady stream of junk coming into some of our forms. Looking up the IPs they mostly seem to originate from Russia and Africa.
    I looked into the subject a little after noticing you've labeled the hidden field in a way that could make it easy for well written bot to pick it out and ignore it.
    Here's some interesting reading for you.
    http://www.smartfile.com/blog/captchas-dont-work-how-to-trick-spam-bots-with-a-smarter-honey-pot/
    I think what might be required here is maybe the creation of a randomizing engine, which obfuscates the form field names on the client side and randomly positions the honeypot field each time the form is loaded.
    Can you look into this ASAP?
    Martin
  • Jan Skovgaard 11280 posts 23676 karma points MVP 10x admin c-trib
    Mar 28, 2014 @ 17:20
    Hi Martin
    What version of Umbraco and Contour are you using?
    If you're using a newer version of Contour you can actually modify the forms.cshtml yourself - That's probably the quickest option.
    I do agree that it would be nice to have this changed in the core of Contour but it sounds like something you need to fix in a hurry.
    So now you know where to look if you're using a newer version of Contour - And I think you should create feature request on the issue tracker at http://issues.umbraco.org/issues and I'm sure it is something the HQ will take into consideration. And perhaps you can even submit a pull request if you figure out something really nice? :)
    Hope this helps.
    Mar 28, 2014 @ 17:37
    Martin Griffiths
    Hi Jan
    Yep, I appreciate I could move the field to a different position, but unfortunately the ID of the field has an all too obvious name!
    M.
    Mar 28, 2014 @ 17:42
    Hi Martin
    That's true - and fortunately it's an easy fix but it's stille going to be planned and a release should be made etc. So simply changing the field-name and id could perhaps be enough.
    If you file a report on the tracker I'll be happy to vote it up.
    Mar 28, 2014 @ 17:45
    Martin Griffiths
    Awesome Jan,
    http://issues.umbraco.org/issue/CON-537
    Martin
  • bob baty-barr 1180 posts 1294 karma points MVP
    May 18, 2015 @ 19:08
    bob baty-barr
    so, is this issue indeed fixed? and how can i tell if there is a honeypot?
