Sometimes opening forms, or for example clicking the "Umbraco Contour" node takes a lot of time. I suspect there's a server side call which is blocked by the firewall and it times out. Also, I've noticed a umbraco.licensing.log.txt file in App_Data that contains several paragraphs like:
Could not validate license:
Your license has been approved for the following IPs/Domains: - Domain: www.
- Domain: *.
The umbracoForms.lic file is in the bin folder. Is there a domain for validating the licence that has to be allowed in the firewall?
Which version are you running, make sure to upgrade to the latest :) and also make sure that your license is valid for all domains that the site supports
Thanks for your reply! Version was 3.0.18, now updated by extracting UmbracoContour3.0.20update.zip in the root. The "Could not validate license" message still shows up in umbraco.licensing.log.txt, though so far the forms don't take long to open anymore. The site is currently in beta and on a different domain than the live one, so I guess that could be the problem. How can I check for which domains the licence is valid?
Also I noticed that the "Loading..." text remains permanently in the "Learn" panel from the Dashboard tab, and there's an error below "Umbraco Contour version 3.0.20":
Could not load control: '/umbraco/plugins/umbracocontour/formsdashboard.ascx'.
Error message: System.InvalidOperationException: Only one instance of a ScriptManager can be added to the page. at System.Web.UI.ScriptManager.OnInit(EventArgs e) at System.Web.UI.Control.InitRecursive(Control namingContainer) at System.Web.UI.Control.InitRecursive(Control namingContainer) at System.Web.UI.Control.AddedControl(Control control, Int32 index) at umbraco.cms.presentation.dashboard.OnInit(EventArgs e)
Unfortunately after this update a problem appeared. I was using Cultiv RestContour to submit the forms with ajax. Now the strange thing is that unless the project is in debug, the following error occurs:
Exception has been thrown by the target of an invocation.
STACKTRACE:
at System.RuntimeMethodHandle.InvokeMethod(Object target, Object[] arguments, Signature sig, Boolean constructor)
at System.Reflection.RuntimeMethodInfo.UnsafeInvokeInternal(Object obj, Object[] parameters, Object[] arguments)
at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture)
at Umbraco.Web.BaseRest.RestExtensionMethodInfo.Invoke(String[] parameters)
INNEREXCEPTION:
System.MissingMethodException: Method not found: 'Void Umbraco.Forms.Core.Services.RecordService..ctor(Umbraco.Forms.Core.Form)'.
at RestContour.SubmitContourForm.CreateRecord()
We saw this with another user just recently as well, in that case it turned out to be an issue with their code but we did manage to make a few adjustments with the http://nightly.umbraco.org/Umbraco%20Contour/3.0.21/ version. If you don't already have that, can you test an update?
I've just updated to 3.0.21 but unfortunately some issues persist:
-it takes a long time to open a form initially
-the text "Loading..." remains on the dashboard permanently
-below that there's an error: Could not load control: '/umbraco/plugins/umbracocontour/formsdashboard.ascx'.
One thing that works now is submitting the forms with ajax when the project is compiled for release.
Your license has been approved for the following IPs/Domains: - Domain: www. - Domain: *.
It takes 10-15 seconds to open a form with a few properties. Is this normal?
Does anyone know how can we get some support on this product? I couldn't find anything else besides the forum.
Thanks!
Hi bfi,
Try to take a look at this page. Here you can find some support opportunities on the Contour product
http://umbraco.com/help-and-support/customer-area/contour-support-and-download.aspx
E.g there is a section that´s cover license questions.
Since you have buyed the contour, could you try to get supoort this way: http://umbraco.com/contact/support-requests.aspx
Or you try send Umbraco team an email via here and explain the problem with you Contour: http://umbraco.com/contact/send-us-an-email.aspx
Hope this can help you.
/Dennis
Comment author was deleted
Hey,
Hi Tim,
Could not load control: '/umbraco/plugins/umbracocontour/formsdashboard.ascx'. Error message: System.InvalidOperationException: Only one instance of a ScriptManager can be added to the page. at System.Web.UI.ScriptManager.OnInit(EventArgs e) at System.Web.UI.Control.InitRecursive(Control namingContainer) at System.Web.UI.Control.InitRecursive(Control namingContainer) at System.Web.UI.Control.AddedControl(Control control, Int32 index) at umbraco.cms.presentation.dashboard.OnInit(EventArgs e)
Thanks!
Ok thanks yeah must be due to that then, in 3.0.20 there are multiple performance inhencements so glad that is working out :)
STACKTRACE: at System.RuntimeMethodHandle.InvokeMethod(Object target, Object[] arguments, Signature sig, Boolean constructor) at System.Reflection.RuntimeMethodInfo.UnsafeInvokeInternal(Object obj, Object[] parameters, Object[] arguments) at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture) at Umbraco.Web.BaseRest.RestExtensionMethodInfo.Invoke(String[] parameters)
INNEREXCEPTION: System.MissingMethodException: Method not found: 'Void Umbraco.Forms.Core.Services.RecordService..ctor(Umbraco.Forms.Core.Form)'. at RestContour.SubmitContourForm.CreateRecord()
Do you have any suggestions?
Thank you!
Hi -
-Paul
Hi Paul,
Thank you for your reply!
-it takes a long time to open a form initially -the text "Loading..." remains on the dashboard permanently -below that there's an error: Could not load control: '/umbraco/plugins/umbracocontour/formsdashboard.ascx'. Error message: System.InvalidOperationException: Only one instance of a ScriptManager can be added to the page. at System.Web.UI.ScriptManager.OnInit(EventArgs e) at System.Web.UI.Control.InitRecursive(Control namingContainer) at System.Web.UI.Control.InitRecursive(Control namingContainer) at System.Web.UI.Control.AddedControl(Control control, Int32 index) at umbraco.cms.presentation.dashboard.OnInit(EventArgs e)
Thanks!
