Contour not showing entries - UFrecordsXml is empty
None of the contour forms are showing submitted entries. Viewing the sql query, they do not show up because the table UFrecordsXml is empty (breaking the joinn), though there are 6 entries in the other uf tables.
Any ideas why the UFrecordsXml table is not being populated? I am using v6.1.6 and the contour was installed from the package repository.
Thanks, Robert
sql:
exec sp_executesql N'SELECT count(*) from UFrecordsXml
INNER JOIN UFrecords on UFrecords.id = UFrecordsXml.Id
where UFrecordsXml.form = ''26c223d6-7d2a-4c01-98eb-17cd63591020''
and UFrecordsXml.created > @created and UFrecords.state IN (3)',N'@created datetime',@created='Mar 30 2014 4:28:11:000PM'
Where you every able to figure out why this was happening? I am seeing the same thing. It only seems to be a small number that are not being added to UFRecordsXml table, but I dont know why they are not being added.
Clair, the problems I had were due to using SQl server 2005 and a userid and password to connect. We upgraded to SQL Server 2012 and used integrated security in the connection which fixed the issues.
Another thing to check is if the server has nocount = off. To commit the records contour expects a record count being returned, 0 or greater. NOCOUNT returns -1.
Thanks, Robert
sql:
http://our.umbraco.org/documentation/Installation/system-requirements
Bob
