  • J 447 posts 864 karma points
    Apr 01, 2014 @ 17:23
    J
    Comparetextbox.cshtml is missing
    Im trying to compare an email address so downloaded some addons from http://www.nibble.be/?p=107.
    Once installed i saw the compare option but viewing the form i get an error that the file Fieldtype.comparetextbox.cshtml is missing.... i cant seem to find it anywhere. Could anyone advise how to fix this?
    Apr 01, 2014 @ 21:37
    Hi J
    Not sure if this is still supported in newer versions of Contour. What version are you using?
    Apr 02, 2014 @ 10:10
    J
    Hello
    Im using 3.0.17 which i assume is the latest version - what options would i have if its not supported?
    Apr 02, 2014 @ 10:18
    Hi J
    Ok - Latest version as far as I know is 3.0.20 - However I'm not sure if the above will work. The blogpost was about version 1.1.9 of Contour.
    I'm not saying that it's intended this should not work but perhaps something has changed along the way, which makes it not work.
    I can see that you're not the only one who is having trouble getting this to work http://www.nibble.be/?p=107#comment-288789
    So perhaps it's a good idea to report it as a bug on the issue tracker
    Apr 02, 2014 @ 13:05
    J
    Thanks - what version of Contour would be stable with Umbraco 6 XXXX
