I'm using uLocalGovMVC for our templates and installed Contour.
The datepicker is working correctly in the preview but on the published form (macro on page), the date picker doesn't appear, it only works as a text box.
Kevin Jump did wonder if I need to add the Client Dependency Framework to the master pages - would that be correct and how would I go about doing that?
Out of the box without adding the missing script files, I get (although the form submits and sends an email without any problem)
Uncaught ReferenceError: jQuery is not defined contourform.js:57
Uncaught ReferenceError: jQuery is not defined (index):413
init: Chrome : 33 zozo.tabs.js:30
event.returnValue is deprecated. Please use the standard event.preventDefault() instead.
If I add the missing script files I get
Uncaught ReferenceError: jQuery is not defined jquery.validate.unobtrusive.min.js:5
Uncaught ReferenceError: jQuery is not defined jquery.validate.min.js:50
GET http://umbraco.northdevon.gov.uk/font/fontawesome-webfont.woff?v=3.0.1 404 (Not Found) (index):392
Uncaught ReferenceError: jQuery is not defined jquery-ui-1.8.11.min.js:22
event.returnValue is deprecated. Please use the standard event.preventDefault() instead. jquery-1.10.2.min.js:5
either way, the datepicker doesn't appear when you click in the field.
Uncaught ReferenceError: jQuery is not defined (index):216
If I add the files into the header at just before the </head>
I even created copies of the style sheets and javascript files so that they were called using /scripts/jquery-ui-1.8.11.min.js etc but that didn't make any difference.
I came across the same issue with Contour form not showing the date picker.
Once you ensure the jqueryui css,js along with the default included jquery js are in place,
DatePicker works in preview but not on web form
Are you rendering with razor or usercontol?
Try rendering with razor
I diopped a macro (of the contour form) into the text on the page - everything else works correctly, just the date picker doesn't
In preview mode inspect the javascript you might be missing some of them when rendering the form your template.
There is this code missing
But if that's important js files, why isn't Contour generating that as part of the macro?
Think this may be similar to this http://our.umbraco.org/forum/umbraco-pro/contour/49560-Contour-pre-requisites
I have got a bit further.
If I don't add these files in the header, the form submits correctly but the date picker doesn't show
it does javascript console error with
</head>then I don't get the jQuery is not defined errors and the date picker appears.
All well and good apart from when I start entering data in the other fields I get
and the form doesn't submit.
does anyone have any ideas of how I can move forwad
Steve,
Have you found a solution to this? I'm running into the same problem.
Google hasn't yielded any working fixes.
Moriyama did a tweak to which jQuery file was loading which fixed it for about 10 minutes but it then stopped working again!
Will get them to have another look in the next month (holiday and training courses getting in the way) and if we do solve it, I'll let you know.
I came across the same issue with Contour form not showing the date picker. Once you ensure the jqueryui css,js along with the default included jquery js are in place,
simply change your jquery js with following:
the second one (migrate) ensures the obsolete msie detection routines are removed and lets the script run without errors, and datepicker works.
as per (reference): http://jquery.com/download/#jquery-migrate-plugin
