  • Joachim Andersen 38 posts 198 karma points
    Apr 07, 2014 @ 11:16
    Joachim Andersen
    Upload field not working?
    I'm trying to create a form with an upload field but the files I attach is not uploaded. I get no errors so I don't have any ideas where to look. Any ideas?
    Cheers, Joachim
    Apr 07, 2014 @ 12:29
    Joachim Andersen
    Ok, I can see that there is not always added a form tag surrounding the form fields, if there is no form tag the file is not uploaded. I'm not really able to see any patterns, it seems random when the form tag is added and when it is not. Anyone out there which has seen/solved the problem?
    Cheers, Joachim
    Apr 07, 2014 @ 12:37
    Joachim Andersen
    If I insert the same form twice the second form is surrounded by a form tag, and then I'm able to submit files???
    Apr 09, 2014 @ 09:11
    Joachim Andersen
    By the way - I'm using webforms
