  • Tom Steer 161 posts 596 karma points
    Apr 07, 2014 @ 17:41
    Tom Steer
    RenderMacroContent Contour
    I'm currently loading content via an ajax call to a base method. However i'm having issues when the RTE contains a contour form. I have tried the following but it currently errors:
    flowResult.Outcome = library.RenderMacroContent(Umbraco.Web.Templates.TemplateUtilities.ParseInternalLinks(node.GetProperty<string>("outcome")), node.Id);
    I currently get the following:
    Error loading MacroEngine script (file: MvcRenderContourForm.cshtml)
    With an error in the logs of:
        2014-04-07 10:35:20,671 [10] WARN  umbraco.macro - [Thread 9] Error loading MacroEngine script (file: MvcRenderContourForm.cshtml, Type: ''. Exception: System.NullReferenceException: Object reference not set to an instance of an object.
       at umbraco.NodeFactory.Node.getCurrentNodeId()
       at umbraco.macro.loadMacroScript(MacroModel macro)
       at umbraco.macro.renderMacro(Hashtable pageElements, Int32 pageId)
    Many Thanks,
    Tom
    Apr 08, 2014 @ 21:58
    Tom Steer
    Any advice would be greatful... really need to find a solution to this.
