  • Craig Barraclough 4 posts 24 karma points
    Apr 08, 2014 @ 15:53
    Craig Barraclough
    Upgrade Contour from 3.0.6 to 3.0.20 on Umbraco 4.9.0
    Apologies if this has been answered elsewhere, i couldn't find a clear answer. I'm running Contour 3.0.6 on Umbraco 4.9.0 but i'm having a few issues with the conditional logic and i'd like to upgrade contour. I have a couple of questions.
    1. Can i upgrade to 3.0.20 from 3.0.6 on U 4.9.0?
    2. I've seen it written that to upgrade it's a simple xcopy to replace files, could you give me a clue how to do this? i'm obvously simplier than the command and don't know how to do this.
    cheers
    Craig
    Apr 08, 2014 @ 17:15
    Hi Craig
    I think it should be possible to upgrade Contour on that specific version. You can see the guide on upgrading here http://our.umbraco.org/projects/umbraco-pro/contour/documentation/Installation/Upgrade
    But please be aware that Contour 3.0.20 will need the MVC 4 framework to be installed - otherwise it won't work.
    And before doing anything make sure to do a backup of your files and database.
    In regards to using xcopy that is probably when one is building a solution and wants to output the result to another folder or place on the disk. That should not be necessary for upgrading Contour.
    Hope this helps.
    Apr 16, 2014 @ 17:06
    Craig Barraclough
    Hi Jan,
    Thanks for the advice, just on the xcopy point, on the upgrade instructions under Extract the Archive and Overwrite files it says "These new files need to be xcopied over the existing ones...". This is the bit i'm struggling with, how do I xcopy the files?
    cheers
    Craig
    Apr 16, 2014 @ 17:32
    Craig Barraclough
    Hi Jan,
    cheers
    Craig
    Apr 30, 2014 @ 16:38
    Craig Barraclough
    Hi, I still need help with the xcopy if anyone can help.
    cheers
    Craig
