  • Craig100 1136 posts 2523 karma points c-trib
    Apr 11, 2014 @ 04:33
    Craig100
    Input field class
    Is there any way to add classes to the input fields? I'm using Bootstrap and need to add the form-control class to the input elements.  I've managed to create a specialised form using the GUID directory format but the input field seems to come from a prebuilt partial. Never used Contour before but just hope it's not going to take as long to set up as it'd take to roll my own email sender, as is often the case with some packages ;)
    Craig
    Apr 11, 2014 @ 05:41
    Craig100
    Forgot to mention placeholder text as well?
    Craig
