  • Thomas 160 posts 335 karma points
    Apr 14, 2014 @ 12:27
    Thomas
    Error: Unable to get property 'setDefaults' of undefined or null reference
    I am getting the error
    on load on the Contour Macro Script in Umbraco 6.1.6 content page (contactus.aspx).
    Any suggestions please?
    Apr 14, 2014 @ 14:54
    Thomas
    I resolved the issue. It was jquery scripts reference issue.
  • Jeff Kwong 31 posts 51 karma points
    May 07, 2014 @ 02:14
    Jeff Kwong
    I'm having the same problem! How did you solve it?
  • Matt Linsenbardt 24 posts 147 karma points
    May 07, 2014 @ 19:36
    Matt Linsenbardt
    @Thomas may be referring to adding the script references noted in this blog post:
    http://umbraco.com/follow-us/blog-archive/2012/11/9/getting-started-with-contour-30-beta.aspx ;
    May 09, 2014 @ 00:18
    Jeff Kwong
    Ah, that did the trick. Thanks, Matt!
