  • Robert Brown 18 posts 38 karma points
    Apr 23, 2014 @ 21:17
    Robert Brown
    how do i use Contour Library methods in Umbraco v7.1.1
    I understand that Umbraco version 7 did away with extended xslt. So how can I use the former macros such as GetApprovedRecordsFromPage using the UI. The macros don't exist in version 7 so is there a new way to get records instead of using xslt?
    Robert
    Apr 23, 2014 @ 22:04
    Dennis Aaen
    Hi Robert,
    I found some documentation for working with data from Contour in Razor,
    http://our.umbraco.org/projects/umbraco-pro/contour/documentation/Developer/Working-with-Contour-data-in-Razor/
    I hope this help you in some way.
    /Dennis
    Apr 24, 2014 @ 21:57
    Robert Brown
    Thank you, That got me close.
    Robert
    Apr 25, 2014 @ 10:28
    Dennis Aaen
    Hi Robert,
    Did you find out how to use the Contour Library methods in Razor. If not this could be a an example of how to get GetRecordsFromForm:
    @Umbraco.Forms.Mvc.DynamicObjects.Library.GetRecordsFromForm("e14b84d2-3aab-413a-95da-7bc29521572b");
    http://our.umbraco.org/forum/umbraco-pro/contour/50231-GetRecordsFromForm-in-Razor?p=0#comment179809
    /Dennis
    Apr 25, 2014 @ 15:49
    Robert Brown
    Yes, I had to modify the document example and have a basic razor script working. Here it is:
    @inherits umbraco.MacroEngines.DynamicNodeContext
    @using Umbraco.Forms.Mvc.DynamicObjects
    <ul id="comments">
     @foreach (dynamic record in
               Umbraco.Forms.Mvc.DynamicObjects.Library.GetApprovedRecordsFromPage(@Model.Id).OrderBy("Created"))
         <li>
              @record.Created.ToString("dd MMMM yyy")
              @if(string.IsNullOrEmpty(record.Website)){
                 <strong>@record.Name</strong>
              else{
                 <strong>
                   <a href="@record.Website" target="_blank">@record.Name</a>
                 </strong>
             <span>said</span>
            <p>@record.Comment</p>
         </li>
    </ul>
    Robert
