  • Jacob Polden 67 posts 178 karma points
    Apr 25, 2014 @ 12:00
    Jacob Polden
    Pair of code behind forms alternate fully rendered state
    I am having this issue which is quite bizarre and quite hard to explain. In my Umbraco Contour install I have a mix of regular forms as well as two "code first" contour forms.
    LearnerRegistration
    and
    TutorRegistration
    Both forms are in a separate UmbracoSite.Forms project, in the same UmbracoSite.Forms namespace. The project compiles into one dll.
    When I copy the dll to my Umbraco site the forms appear in the back office, in Contour. However only one form will fully render at a time.
    When form Learner Registration is fully rendered then only the field sets on form Tutor Registration will render - this is also reflected on the front end of the site, only one form is useable at a time. See below:
    Tutor Registration Learner Registration
    This then alternates when I restart the app pool. The Tutor form will fully render and the learner will only display field sets. I have even looked at the table entries in the database for contour, and the field table entry count increases and decreases with every app pool restart.
    Forms in DB
    I am using Umbraco 6.1.6 and Contour 3.0.20 - any input is greatly appreciated
