  • Chris 1 post 21 karma points
    Apr 29, 2014 @ 13:05
    Chris
    My license URLs need ammendment
    Hi there,
    I'm new to Umbraco, so pardon me if this is a dumb question.
    I just bought a license for Contour. However, I need to test the form submissions and whatnot.
    The development URLs in the license document are both not working.
    • My localhost has a port after it, which I did not add to the file. I.E: localhost:30116
    • The staging site which my client is using to test the site is supposed to be eqstrafleetmanagement.azurewebsites.net, but it was put down as a .com.
    I just need these two simple ammendments to be made, but there is no apparent way to do so.
    From what I have read, it seems that to get support on this I need to have the $3000 subscription, which is rather harsh.
    Please help.
  • Tim 1193 posts 2675 karma points MVP 4x c-trib
    Apr 30, 2014 @ 16:01
    Tim
    You can get the domains changed on the license pretty easily. Just contact via the email link on http://umbraco.com/contact.aspx and they should sort you out. We've had to change the domains on licenses a few times when clients have been taken over or renamed.
    I think localhost should just work anyway.
