On umbraco 6.1.6 and contour version 3.0.20 running under trail mode. After submitting the Contour form getting the following exception
Method not found: 'Void Umbraco.Forms.Core.Services.RecordService..ctor(Umbraco.Forms.Core.Form, Boolean)'.
please suggest
Hi Krishna and welcome to our :)
How did you install Contour - Did you do it manually or by using the package?
Installed the contour manually.
Hi Krishna
Ok...did you perhaps miss a step from the installation guide?
What database are you using?
Jan,
SQL server, followed the installation documentation available
Could you try looking for this in the web.config ContourFormBuilderHttpModule - What happens if you remove all entries with this name?
Comment author was deleted
Maybe missing an assembly? Do you have Umbraco.Forms.Core in the bin dir?
Tim & Jan,
Thank you. Taken a copy of bin from another installation which has resolved the issue
Upload image
please suggest
Hi Krishna
Jan,
Hi Krishna
Tim & Jan,
