  • Krishna 6 posts 26 karma points
    May 08, 2014 @ 09:39
    Krishna
    Method not found: 'Void Umbraco.Forms.Core.Services.RecordService..ctor(Umbraco.Forms.Core.Form, Boolean)'.
    On umbraco 6.1.6 and contour version 3.0.20 running under trail mode. After submitting the Contour form getting the following exception
    please suggest
    May 08, 2014 @ 10:23
    Hi Krishna and welcome to our :)
    How did you install Contour - Did you do it manually or by using the package?
    May 08, 2014 @ 10:44
    Krishna
    Installed the contour manually.
    May 08, 2014 @ 10:47
    Hi Krishna
    Ok...did you perhaps miss a step from the installation guide?
    What database are you using?
    May 08, 2014 @ 10:56
    Krishna
    Jan,
    SQL server, followed the installation documentation available
    May 08, 2014 @ 13:01
    Hi Krishna
    Could you try looking for this in the web.config ContourFormBuilderHttpModule - What happens if you remove all entries with this name?
  • Comment author was deleted
    May 08, 2014 @ 13:06
    Maybe missing an assembly? Do you have Umbraco.Forms.Core in the bin dir?
    May 08, 2014 @ 15:19
    Krishna
    Tim & Jan,
    Thank you. Taken a copy of bin from another installation which has resolved the issue
