  • Martin Lingstuyl 202 posts 379 karma points
    May 08, 2014 @ 23:14
    Martin Lingstuyl
    UFRecordsXML Not updated
    Hi guys,
    I'm using some forms with manual approval set to true and some custom logic which updates the status of records to approved at a later stage.
    However, when I look in the UFRecordsXml table, the records that should be approved are still set on submitted. In the entries viewer all is showing as it should, but the xml cache is apparently out of sync.
    This also scrambles the export functions, which export the xml cache.
    Does anyone know how to rectify this?
    Martin
    May 09, 2014 @ 11:21
    Martin Lingstuyl
    For anyone:
    I had apparently overlooked this thread: http://our.umbraco.org/forum/umbraco-pro/contour/43696-Regenerate-Contour-XML
    This fixed my issue, though I hope it won't reoccur.
    Martin
