Hi all,
I need to render a different form view for a specific form in Contour. Using Umbraco v. 7.1.2 and Contour v. 3.0.21.
In Form.cshtml, I have a simple if statement checking if the form GUID is equal to the form I need rendered differently.
Snippet from Form.cshtml:
@if (Model.FormId.Equals(new Guid("831e7420-5d1f-4c71-8278-e62b46ba9a2f"))) { @Html.Partial("~/Umbraco/Plugins/umbracoContour/Views/NewsletterForm.cshtml", Model) } else { // Render the normal form view }
The newsletter form renders just fine, but when I click the submit button it gives me this:
Index was out of range. Must be non-negative and less than the size of the collection. Parameter name: index
I've debugged the code and the exception seems to happen in this call:
@Html.RenderMvcAction(action, controller, formGuid, formtoken, (umbraco.MacroEngines.DynamicNode)Model, (System.Dynamic.DynamicObject)Parameter);
in MvcRenderContourForm.cshtml
I'm just not sure what collection is empty :-)
Is this the "right" approach to render forms with a difference view?
Thanks in advance!
Here is the official documentation for changing markup of contour forms : http://our.umbraco.org/projects/umbraco-pro/contour/documentation/Developer/Custom-Markup/
Maybe these blog posts can be usefull too :
http://umbraco.com/follow-us/blog-archive/2012/11/8/contour-30-features-full-control-over-form-markup.aspx
http://www.nibble.be/?p=121
Comment author was deleted
You can have specific views for a single form, check documentation here http://our.umbraco.org/projects/umbraco-pro/contour/documentation/Developer/Custom-Markup/ :)
Thanks guys, learned something new there :-)
I've simply created a new folder with the newsletter form guid, copied the original Form.cshtml to it and modified it and everything works as it should now.
Thanks again!
Render different view depending on form guid
Hi all,
in
MvcRenderContourForm.cshtmlI'm just not sure what collection is empty :-)
Thanks in advance!
Thanks again!
