  • Fergus Davidson 309 posts 588 karma points
    May 30, 2014 @ 14:07
    Fergus Davidson
    Contour adding WhiteSpace befor Razor Macro
    i have the issue in the following thread:
    http://our.umbraco.org/forum/umbraco-pro/contour/39517-Contour-adds-whitespaces-before-Razor-macro-which-mess-up-layout
    I want to upgrade from Contour v3.0.6 in Umbraco v4.11.1
    There is an install download on the Contour page, but not an Upgrade for Umbraco v4
    Do i:
    1. reinstall Contour over the top using v4 installer?
    2. need an upgradezip for Umb v4?
    3. use latest upgrade zip?
    thanks
    May 30, 2014 @ 14:15
    Hi Fergus
    Perhaps you can follow the manual upgrade steps from here http://our.umbraco.org/projects/umbraco-pro/contour/documentation/Installation/Upgrade
    I think I would try using the upgrade script as you suggest above yourself - However before doing anything then make sure to backup both your files and the database. There is no gurantee it will work...I'm not sure whether or not Umbraco 4.11 is supported any longer or not.
    But Think that at least 3.0.14 should be - so perhaps you could grab the necessary files from http://nightly.umbraco.org/Umbraco%20Contour/
    Hope this helps.
    May 30, 2014 @ 15:30
    Fergus Davidson
    Thanks Jan.
    worked perfectly!
    I installed the v3.0.10 manual install as i know that that fixed the issue and is compatible from the previous thread i mentioned above.
    Does anyone know of any specific issues in v 3.0.10 that i should upgrade to a later version.
    Also which is the latest i could sfely upgrade to in this way?
    Thanks again Jan
    May 30, 2014 @ 15:32
    Fergus Davidson
    sorry, marked the wrong post as solution. sorry Jan
    Jans post is the solution. link to nightlies, download manual version.
