Is this possible with the latest version of Contour? I am trying to see if Contour can do what a form created using FormDesk does.
For example, 2 radio buttons to choose option (member / non-member). Price is either £35 or £70.
Between 1 and 4 players can be submitted, total needs to add up each player cost.
There is more to it than that, but that is the basics.
Comment author was deleted
Nothing in the UI that makes that possible but you can calc in the workflow
Hi Tim,
This is something we are also currently interested in, do you have any hints on the best way to do this in the workflow? build a custom workflow?
Thank you,
Matt
Calculated fields
Hi Tim,
Thank you,
Matt
