  • Joseph 59 posts 140 karma points
    Jun 03, 2014 @ 06:57
    Joseph
    Contour Export Entries not working consistently
    I'm working with a form with a bunch of multi-line text boxes which could be taking in a large amount of text (i.e. a couple of paragraphs). I've noticed that when I try to export entries (using the button at the top left corner), I do not get consistent results: I do not always gets all the results as I would expect; for instance I might get a report made out of 2 out of 5 entries. This is regardless of the format requested i.e. HTML or CSV. Subsequent requests obtain different results i.e. 3 out of 5 entries or 4 and a half out of 5 (i.e. the fourth entry has some missing information).
    This is on Umbraco Contour 3.0.9.
    Is this a known issue or is there a known resolution or workaround for this issue?
  • Lasya 38 posts 70 karma points
    Jun 03, 2014 @ 10:37
    Lasya
    Hi Joseph
    Did you remove Partially Submitted entries. I think it will be fine if you remove entries from partially submitted section and try to export after removing them.
    Lasya.
    Jun 03, 2014 @ 22:04
    Joseph
    Nope all five entries are fully submitted and approved.
    Jun 16, 2014 @ 01:26
    Joseph
    Any help for this please?
