Allows you to load a specific form with a specific record (e.g. to edit).
Would it be possible to have an input for a record id in the standard Razor macro to render Contour forms? Out of the box support for record editing on the front-end would be nice...
Render a form with specific record loaded?
In contour package, previewFormDialogMvc.aspx is provided.
Kris
