Using Conditional Logic in Tandem with Field Order in "Save as Umbraco Document" Workflow
@Tim
Can this be done w/a custom workflow?
Two radio buttons on form:
If Radiobutton A selected -> then save document type and all matched fields in workflow to Parent A in Umbraco Tree.
If Radiobutton B selected -> then save document type and all matched fields in workflow to Parent B in Umbraco Tree.
In other words, there is currently one tree control in the Save as Umbraco workflow? Could you add more than one or process a variable to the Save as is different?
@Tim
