Im running a Umbraco v6.1.6, and it has been working fine until a few days ago. It started to get slow.
It is very quick to login to umbraco backoffice, and to show some of the nodes in content. But one documenttype is slow and takes about a minut to load.
The slow documenttype only have a rich text editor property, but each node of this documenttype has added a contour razor macro in the property.
If i add a node without a contour macro it is quick to load.
The site is running in https, iis 7.5, network service, v4 .net , windows server 2008 R2.
I have a test site running on the same server (not https) which runs just fine. The test site and the live site have its own database but the database is on the same sql instance.
There are no errors in the log in the database
Im using contour 3.0.17
What can i do with the contour - our customer is getting nervous and they cant edit anything because it is that slow
If upgrade is a opportunity, maybe you could try to upgrade you contour installation to version 3.0.21, to see if this makes any speed difference for your content section.
Contur is making content section very slow!
Note, it is also very slow when i add a form that has no fields and no workflows.
Hi Anne,
I can see you are using Contour 3.0.17, and I can see from the space for Contour on our that the lastest version is 3.0.21. http://our.umbraco.org/projects/umbraco-pro/contour
Hope this helps,
/Dennis
