I have a question - is it possible to apply the same technique (#DictionaryItem) to the "Submit" button (and the "Previous" and "Next" buttons in multi-step forms)? Or are we stuck with English for these elements?
Also noticed that the validation messages could do with allowing #DictionaryItem references, so you could have multi-lingual validation error messages. For example, for a mandatory field, you could enter "#ContactName #ContactMandatory" as the validation "Required Error Message", and then have dictionary items eg:
Submit button, will fetch it's value from the dictionary item submit (if it exists) Next button, from next Previous button from previous
And you can also use dictionary items in the validation messages, just create a dictionary items and then instead of having a static value in the Form properties set it to the dictionary item #myitem
And in that copy you'll have to add the field name. So "Name ist obligatorisch".
Or you could set the required error message on the settings tab to #ContactRequired and use this syntax.
{0} ist obligatorisch in the dictionary item.
So if you set the requred error message on the settings it's for all messages on the form. If you set it on the field it's only for that specific field.
If you set the message on the field itself it is for this field only. And the {0} syntax won't work. Since it is for a single specific field, and you'll now the caption ..
But if you set for the entire form (on the second tab) then you can use the {0} syntax. But you'll also have to remove the message on the field.
Ah right, I didn't spot that setting on the second tab. I've tried that, and it's still not quite working as I'd like. In my dictionary item ("ContactRequired"), I've put "{0} ist obligatorisch", but I've also used dictionary items for my form field names ("#ContactName", "#ContactEmail", "#ContactMessage").
If I put #ContactRequired into the setting on the second tab, the errors shown are things like "#ContactName ist obligatorisch", so it's then not picking up the field names from the Dictionary.
Contour for multi-lingual sites
I've just watched the excellent video on how to manage forms for multi-lingual sites at http://umbraco.org/documentation/videos/umbraco-pro/contour/manage-multi-language-forms
Mike
#ContactName = "Name" / "Nom"
#ContactMandatory = "is required." / "est obligatoire"
Make sense?
M
Comment author was deleted
Hi Mike,
Sure it is possible:
Hi Tim
That doesn't seem to work - take a look at this quick screencast...
http://screencast.com/t/NWNjZDBhOT
Any ideas? Should it work?
Mike
Hi Mike,
Yes, you can only add 1 dictionary item.
So you should use #ContactRequired
Hi Tim
The {0} doesn't seem to work - the error message just shows "{0} ist obligatorisch" - see http://screencast.com/t/YWViM2M4MGY
Any ideas? Have I missed something?
Mike
Hi Mike,
Tim
Hi Tim
See http://screencast.com/t/NDU2YThlY
Mike
I have this problem as well.
But mine is narrowed down to the "Settings" tab. And I am not able to use dictionary items for Required error message and Invalid error message.
Is the syntax below wrong? Because it does not work...
{0} #MandatoryErrorMessage
{0} #InvalidErrorMessage
Best regards,
Kalle Ekstrand
Hey Kalle,
You need to set the error message to #dictionaryKey
And then in your key have {0} is mandatory
Thanks Tim,
That makes sense. Now it works like a charm.
//kalle
