  • Wing 17 posts 39 karma points
    Jul 14, 2014 @ 10:26
    Wing
    Razor Record.HasField() always return true
    I've a weird problem using razor script in Umbraco 4.11.7 with Contour 3.0.5.0.
    See following code:
    var form = new DynamicForm(formId);
    var cRecords = form.Records.Items.Where(x => x.State == Umbraco.Forms.Core.Enums.FormState.Approved);
    foreach (dynamic record in cRecords)
      var check = record.HasField("Comment");
    No matter what value I pass to HasField, it always returns true, even if it doesn't exist nor has exist before. If I do the following check after the previous one:
    record.GetField("Comment") != null
    Obviously it will throw error if it doesn't exist.
    Anyone else has this problem?
    Thanks for reading.
