Creating form with code first and conditional logic
I am creating a form using code first and conditional logic. However, I am having an error message on displaying the form 'Sequence contains no matching element' when adding the conditional rule. Please refer to the code below. Can you please advise where am I going wrong? Thanks
Any suggestions how you managed to get it working ?
Am working with a custom field Label but cant get the conditional logic to work.
public class DCLabel : FieldType
[Umbraco.Forms.Core.Attributes.Setting("Text to Display ", prevalues = "", description = "Enter the text to show in the label", control = "Umbraco.Forms.Core.FieldSetting.TextArea")]
public string LabelToShow { get; set; } }
For the conditional logic to work, you need to add a dummy condition like for example,
[FieldConditionRule("Field name", FieldConditionRuleOperator.Is, " ")]
For the 'Code Sequence' error, you need to check that you are not using the same field names anywhere.
Hey Aaeda,
Have you been able to get the conditional logic working on this ?
//fuji
Hi Fuji
Yes I got it working! it's been a while already :)
Aaeda
public class DCLabel : FieldType { [Umbraco.Forms.Core.Attributes.Setting("Text to Display ", prevalues = "", description = "Enter the text to show in the label", control = "Umbraco.Forms.Core.FieldSetting.TextArea")] public string LabelToShow { get; set; }}
Hi Fuji
I don't see the conditional logic you are trying to do. In the code you sent, you are only creating the field.
A.
Sorry here is the code
[Field("test", "test", EnableCondition = true, ConditionActionType = FieldConditionActionType.Show, ConditionLogicType = FieldConditionLogicType.Any)]
[FieldConditionRule("LabelToShow", FieldConditionRuleOperator.Is, "True")]
public string Hidden { get; set; }
Aaeda ... I am having the same problem (my post about it is: http://our.umbraco.org/forum/umbraco-pro/contour/60438-Codefirst-form-error-Sequence-contains-no-matching-element,-multiple-fields-in-db). Would you mind sharing the solution since you got your form working?
Thank you! chester
Hello Chester
For the conditional logic to work, you need to add a dummy condition like for example, [FieldConditionRule("Field name", FieldConditionRuleOperator.Is, " ")]
Hope this helps.
Regards Aaeda
