  • Richard Barg 358 posts 532 karma points
    Jul 31, 2014 @ 22:10
    Richard Barg
    Passing Default Value to Checkbox So Its Checked When Displayed
    If you create a single checkbox field on a Contour form and want it checked by default, there does not seem to be a way to do this. I tried "1" and "true" and the checkbox still displays as empty.
    Is there a way to do this or would this be a feature request.
  • André Nøbbe Christiansen 10 posts 71 karma points
    Aug 01, 2014 @ 01:33
    I'm not that much into Contour but I guess you have to make a if statement to check on that inside the macro where you output your form.
    Aug 01, 2014 @ 01:52
    Richard Barg
    This is part of the main UI for editors in Contour. You should be able to specify a default value that will check the box w/out programming.
    @Tim G. Where are you? Have you checked out? This is my 5th post w/no response.
    Aug 06, 2014 @ 19:02
    Richard Barg
    If the goal is to check a checkbox on the intended (save as) Umbraco document this works, but only if you make this a hidden field and use 1 or 0. There is no way to use a check box field to check a box by default in the form itself.
  • MikeD 92 posts 112 karma points
    May 13, 2015 @ 23:54
    MikeD
    Set default value to true works in Umbraco Forms on Umbraco v7.2.4...
