  • Jonas Nilsson 137 posts 260 karma points
    Aug 05, 2014 @ 11:33
    Jonas Nilsson
    GetApprovedRecordsFromFormOnPage + Razor
    Hi!
    How can I get a RecordField value when iterating records like this? (Error when accessing this field)
    @foreach (dynamic record in Library.GetApprovedRecordsFromFormOnPage(@CurrentPage.Id, "f0170d32-0c46-4648-a0a4-105ca5c26c0e").OrderBy("Created"))
    @record.Comment
    The example commes from this page:
    http://our.umbraco.org/projects/umbraco-pro/contour/documentation/developer/Working-with-Contour-data-in-Razor/
  • Comment author was deleted
    Aug 05, 2014 @ 12:56
    Hey Jonas,
    What is the error you are getting?
    Aug 05, 2014 @ 13:08
    Jonas Nilsson
    Solved, had mixed up the form id's.
    The example works fine when using the corrent field names...
    /Jonas
    Aug 05, 2014 @ 14:02
    Ok glad it's working :)
