I have a checkbox that I want to style by renaming the FieldType.CheckBox.cshtml to correct name.
The name in admin is "Använd leveransadressen" it contains Swedish characters.
I have tried naming it to:
if (System.IO.File.Exists(HttpContext.Current.Server.MapPath(string.Format("{0}/Forms/{1}/{2}.cshtml", Config.ViewsPath, formId, FolderName(fieldName)))))
if (System.IO.File.Exists(HttpContext.Current.Server.MapPath(string.Format("{0}/Forms/{1}/Fieldtype.{2}.cshtml", Config.ViewsPath, formId, viewName))))
Custom view files and International Characters
I have a checkbox that I want to style by renaming the FieldType.CheckBox.cshtml to correct name. The name in admin is "Använd leveransadressen" it contains Swedish characters. I have tried naming it to:
Anvandleveransadressen.cshtml Användleveransadressen.cshtml Använd leveransadressen.cshtml anvandleveransadressen.cshtml
But none of the above works.
Comment author was deleted
This is the code used to fetch the field view
{viewName = FolderName(viewName);Comment author was deleted
Ow and it performs this on the name Regex.Replace(retval, @"\W*", "").ToLower();
So if you do that on your caption and see what it returns that should be the value you need
Hi, this gives me anvndleveransadressen.cshtml
And that does not work either.
