I'm trying to customise the display for one of my forms, i have removed the 'label for' from the form.cshtml and added a placeholder to the fieldtype cshtml. It's worked fine for the text field but the text area seems to be adding spaces and carriage return in the field on the page, if i click in the field and delete the spaces the placeholder shows,
Is it possible for you to show a screendump of the issue or link to a page where it can be seen? I think it will make it easier to understand it.
Also please don't remove the label - Even though you don't want it to be visible you don't wanna remove it! It makes the form inaccessible - a better idea is to hide it using CSS. Use a technique like the below rather than just doing display:none or visibility:hidden since this hides the element from screen readers and crawlers etc.
I faced this particular issue (with white spaces in the textarea element on load) as well and figured out that you need to edit the markup for the file FieldType.Textarea.cshtml in the /umbraco/plugins/umbracoContour/Views folder.
Specifically, you need to make sure that the opening and closing tags are placed on the same line (when you make changes to the file, Visual Studio (2013 in my case) will alter the markup (clean it up)).
Custom Markup using placeholders
I'm using Umbraco 7.1.4, Contour 3.1.21 (trial)
form.cshtml:
<div class="@f.CssClass" @{if (hidden){<text> style="display: none"</text>}}>
@* EDITED OUT LABLE@if(!f.HideLabel){<label for="@f.Id" class="fieldLabel">@Html.Raw(f.Caption) @if (f.ShowIndicator){<span class="contourIndicator">@Model.Indicator</span>}</label>}*@
<div>@Html.Partial(FieldViewResolver.GetFieldView(Model.FormId, f.FieldTypeName, f.Caption), f)
@if (Model.ShowFieldValidaton){@Html.ValidationMessage(f.Id)}</div>
@if (!string.IsNullOrEmpty(f.ToolTip)){<small>@f.ToolTip</small>}
FieldType.Textarea.cshtml:
@model Umbraco.Forms.Mvc.Models.FieldViewModel
<textarea name="@Model.Name" id="@Model.Id" placeholder="@Html.Raw(Model.Caption)"
@{if (Model.Mandatory || Model.Validate) { <text> data-val="true" </text> }}
@{if (Model.Mandatory) { <text> data-val-required="@Model.RequiredErrorMessage" </text> }}
@{if (Model.Validate) { <text> data-val-regex="@Model.InvalidErrorMessage" data-regex="@Html.Raw(Model.Regex)" </text> }}>
@Model.Value
</textarea>
Hi Kerri
FieldType.Textarea.cshtmlin the/umbraco/plugins/umbracoContour/Viewsfolder.Specifically, you need to make sure that the opening and closing tags are placed on the same line (when you make changes to the file, Visual Studio (2013 in my case) will alter the markup (clean it up)).
