  • Scott Mendez 6 posts 26 karma points
    Aug 27, 2014 @ 12:49
    Scott Mendez
    Contour form - uncaught error issue
    So having a problem with the "submit" functionality within a contour form on a page that's been built.
    The issue appears to be that the submit button isn't picking up on the previously defined jQuery, the error is as follows:
    Uncaught TypeError: undefined is not a function jquery.validate.js:109
    The code is:
    valid: function() {
        var valid, validator;
        if ( $( this[ 0 ] ).is( "form" ) ) {
            valid = this.validate().form();
    I'm unsure as to whether this is also affecting the other nested messages to do with errors..
    Any ideas?
    Aug 28, 2014 @ 13:05
    Hi Scott
    It's proably because jquery validate is defined before jquery? Try reading through this post - I think that is the key to a solution http://our.umbraco.org/forum/umbraco-pro/contour/39076-Missing-validation-scripts-when-form-inserted-as-Razor-in-RTE
