  • crono 58 posts 129 karma points
    Aug 29, 2014 @ 15:18
    crono
    GetAllRecords vs. GetRecordsFromForm
    I've run into a small issue when fetching records from the database - specifically the Field data.
    When fetching the data using GetAllRecords, I get all the field values, like SortOrder..
    However, when using GetRecordsFromForm, values like SortOrder are 0 or null.
    I'd prefere to use GetRecordsFromForm as it is 10 times as fast as GetAllRecords.
    Is this a bug, or am I missing something here?
    Also, when fetching data with GetRecordsFromForm, it does not return recently edited records (from using previewFormDialog.aspx) - how come?
    Sep 01, 2014 @ 13:04
    crono
    So, I ended up doing this - but it feels a little wrong..
    Basicly I just grab the ID of the first record entry in the DynamicRecordList, load it through GetRecord() from RecordStorage, and loop through its fields, adding the Keys and SortOrder to a dictionary. Then, when looping through the records, I look up the key in the dictionary and get the SortOrder. Either way - it's a lot faster than GetAllRecords().
    // Get the node
    Node node = uQuery.GetNode(nodeID);
    // Create list to store records
    List<RecordsModel> rmList = new List<RecordsModel>();
    // Get form GUID from node
    var formGuid = node.GetProperty<string>("formGuid");
    // Get all records
    DynamicRecordList records = Library.GetRecordsFromForm(formGuid);
    // Define list for field sorting
    Dictionary<Guid, int> fieldSorting = new Dictionary<Guid, int>();
    // Add fields to sorting if records contain items
    if (records.Items.Count() > 0)
        // Get the first record
        Record r = recordStorage.GetRecord(new Guid(records.Items.ToList()[0].Id));
        // Loop through the record's fields and add the Key and SortOrder to our sorting list
        foreach (var f in r.RecordFields)
            fieldSorting.Add(f.Key, f.Value.Field.SortOrder);
    // Loop through the records
    foreach (var v in records.Items)
        // Create new RecordsModel
        RecordsModel rm = new RecordsModel(v.Id.ToString(), formGuid);
        // Loop through the fields
        foreach (var f in v.RecordFields)
            // Get the SortOrder from the sorting list
            int sortOrder = fieldSorting.ContainsKey(f.Key) ? fieldSorting[f.Key] : 0;
            // Add the field to the RecordsModel
            rm.Fields.Add(f.Value.Field.Caption, new EventRecord()
                Name = f.Value.Field.Caption,
                Value = string.Join(", ", (f.Value.Values.Select(x => x.ToString()).ToArray() ?? new string[0])),
                Index = sortOrder
    // Sort the fields by their index
    rm.Fields = rm.Fields.OrderBy(x => x.Value.Index).ToDictionary(x => x.Key, x => x.Value);
    // Add the RecordsModel to list
    rmList.Add(rm);
