  • Dan Evans 631 posts 1018 karma points
    Dec 04, 2009 @ 11:54
    Dan Evans
    Post to MailChimp
    Is there an obvious way to post Contour form results to MailChimp or would I need to build my own web service to connect to it?
    Dan
    Dec 06, 2009 @ 22:41
    I think you would have to build your own web service to accomplish your task :)
  • Gísli Freyr Svavarsson 43 posts 126 karma points
    Feb 06, 2013 @ 12:30
    hi, guys now three years later i ask the same question: is there a simple way for contour and mailChimp to work together?
    mvh
  • Comment author was deleted
    Feb 06, 2013 @ 14:25
    Feb 06, 2013 @ 14:27
    What that post is is basicly a custom workflow type that makes use of the mailchip api (using a .net wrapper)
  • Steve Morgan 1350 posts 4460 karma points c-trib
    Mar 03, 2015 @ 11:22
    Steve Morgan
    Sorry to dredge up an old thread but here is a working link http://blog.jamesdrever.co.uk/?p=267
    EDIT -
    Acutally reading on.. this is for MailChimp API v1.3 which is deprecated. This is not the modern way to go.
    Install this https://github.com/danesparza/MailChimp.NET  via Nuget (then I had to restart VS to get it to see the reference).. then use the code examples to add to a custom workflow - add the workflow to your form and viola!
  • René Pjengaard 118 posts 702 karma points c-trib
    Mar 08, 2018 @ 10:20
    René Pjengaard
    ...or just post directly to MailChimp. See this post: https://our.umbraco.org/forum/umbraco-forms/81595-umbraco-forms-plus-mailchimp
    /René
